Timing Chain Write-up
Timing Chain Write-up Empty Timing Chain Write-up
Post  CrawlingForward 4/23/2012, 12:50 pm
Did this a while ago, but figured I'd post it up here.
Additionally, when I pulled off my timing chain, I realized my timing chain was set up incorrectly and I therefore had to individually set my all my timing components. So if anything in this write-up seems incorrect or if a component suddenly changes, let me know and I’ll try and correct or make a note of it.
This was in a ’95 YJ 2.5L, so be aware that if you have a 4.0, there’s less room, and therefore something might be different.
All in all, it’s not that bad so long as you don’t change anything’s position once you have the chain and sprockets off. If I hadn’t had to take all the additional steps, it could have been done in an afternoon. I also replace the chain, sprockets, tensioner and oil seal. You may not need to replace all of those components.
Chock all 4 wheels and put the Jeep in gear with the parking brake on. I did a lot of putting the Jeep in and out of gear depending on how easily I wanted the engine to turn over/not turn over.
Timing Chain Write-up 269737_10100166546356616_5503106_47994115_7471330_n
Disconnect battery
Timing Chain Write-up 267660_10100166546426476_5503106_47994116_3737741_n
Remove the 4 nuts that hold on the fan clutch (you’ll most likely need an open ended wrench, as a socket won’t fit)
Timing Chain Write-up 268901_10100166546536256_5503106_47994118_6493944_n
Once you’ve removed the fan and fan clutch, go ahead and take off the 4 bolts that hold on the radiator shroud. With the fan clutch out of the way, you should be able to wiggle it around the radiator hose without needing to disconnect it.
Timing Chain Write-up 283263_10100166546491346_5503106_47994117_604805_n
Next, with the Jeep in gear and the serpentine belt still on, break loose the harmonic balancer bolt. It’ll move a bit, but eventually engine compression will give you the resistance you need.
Timing Chain Write-up 424277_10100166546616096_5503106_47994119_1442818637_n
Once it’s loose, you can remove the serpentine belt by breaking loose the tensioner pulley bolt and then turning out the tensioning bolt on top. Once you’ve got enough slack, you can remove the serpentine belt.
Timing Chain Write-up 320319_10100166546675976_5503106_47994120_2057868730_n
Timing Chain Write-up 299555_10100166546725876_5503106_47994121_8144729_n
Timing Chain Write-up 282139_10100166549121076_5503106_47994161_2737112_n
Next step is to find Top Dead Center. It sounds more complicated than it is.
First, remove all your spark plugs, disconnect the wire to the coil, and put the transmission in neutral. Make sure to label your plug boots so you know exactly where they go when it’s time to put them back. (I love WhiteOut for this purpose) This will also make sure you can easily identify the #1 post on your distributor.
Timing Chain Write-up 281797_10100166546805716_5503106_47994122_1359724_n
Next turn the harmonic balancer bolt (3/4” socket) clockwise until the notch on the harmonic balancer lines up with the zero mark next to it.
Timing Chain Write-up 295929_10100166546905516_5503106_47994124_415459_n
Now, the notch can and sometimes does slip, as it can sometime separate from the rubber. If you suspect this may be the case, you can verify the piston is at the top by inserting a long screwdriver into the sparkplug hole and slowly rotating the harmonic balancer until you feel the screwdriver come to the peak of travel. (Be careful, though, that you don’t accidentally get the screwdriver caught. It’s easy to do)
Once you’re certain that the piston is at TDC, you need to make sure that it’s on the combustion stroke (as opposed to exhaust stroke). You do this by verifying distributor rotor position. First, mark a white-out mark on the distributor housing directly underneath the number 1 cylinder plug wire. Remove the two screws holding on the rotor cap and look to see if it’s pointing at the mark you just made.
Timing Chain Write-up 269672_10100166546960406_5503106_47994125_2336422_n
Mine was pointing 180* off (see the white mark at about 4 o’clock?). If this is the case, you need to rotate the harmonic balancer one more full rotation until the mark is at zero again and your rotor is pointing at your mark.
Timing Chain Write-up 430874_10100166547000326_5503106_47994126_402053695_n
Timing Chain Write-up 401277_10100166547075176_5503106_47994127_516354216_n
Congrats! You are now at TDC! Go ahead and reinstall your spark plugs and put the Jeep back in gear.
Next step is to remove the harmonic balancer. Make sure you get the correct tool/adapters for this. I originally used the tapered adapter with the bolts that thread into the balancer, which put pressure on the threads of the central bolt-hole, which needed to be retapped during re-installation.
Timing Chain Write-up 269438_10100166547140046_5503106_47994128_6181020_n
I ended up using the kind that grabs the balancer that grabs the balancer from behind and pulls it off, mostly because the bolts from the other kit didn’t fit.
Timing Chain Write-up 424107_10100166547179966_5503106_47994129_1797374689_n
Once the balancer is removed, the next step is to prep for taking off the timing chain cover. The idea given to me was to make a representation of it on cardboard and place the bolts in the appropriate spot (there are a number of different types of bolts that need to go back where they came from)
Timing Chain Write-up 268916_10100166547334656_5503106_47994131_3154937_n
Timing Chain Write-up 423569_10100166547254816_5503106_47994130_721840729_n
Once all the bolts are off, go ahead and pull the cover off to reveal...TADA! The timing chain!
Timing Chain Write-up 282520_10100166547424476_5503106_47994133_2017276_n
Timing Chain Write-up Empty Re: Timing Chain Write-up
Post  CrawlingForward 4/23/2012, 12:51 pm
Time to inspect if your chain has extra slack/stretch, is worn, chipped, pitted or has rust or corrosion. It’s recommended the chain be replaced every sixty to hundred thousand miles, but typically they will last the life of the engine without much issue. If you’re this far and have any doubt, you might as well replace it.
For the following steps, make sure to stuff a rag in the oilpan opening to make sure no debris fall in.
Now you can go ahead and unbolt the camshaft sprocket bolt, using the engine compression to keep it from moving.
Timing Chain Write-up 267759_10100166547469386_5503106_47994134_2661669_n
Next remove the timing chain tensioner for inspection. Do this by relieving the tension by turning the un-locking mechanism and removing the c-clip holding it on the peg. Check for excessively deep grooves or the spring being worn enough that it doesn’t create proper tension. Replace if you see the need.
Timing Chain Write-up 270305_10100166547938446_5503106_47994142_8172403_n
Timing Chain Write-up 284473_10100166547873576_5503106_47994141_500096_n
Next you can go ahead and pull off the timing chain and both sprockets as a unit. Take off the oil slinger and you are left with this!
Timing Chain Write-up 285448_10100166547529266_5503106_47994135_3020391_n
Now set the old timing chain next to the new one and set up the new one to match the old.
Timing Chain Write-up 284231_10100166547683956_5503106_47994138_2153522_n
(Both timing chains should look like the one on the right. If you’ve noticed, mine wasn’t and that was part of my running issues). When the timing chain is on correctly, when the timing mark on the camshaft sprocket is at 1 o’clock, there should be 20 pins between the marks, as represented in the diagram (1996 and earlier).
Timing Chain Write-up 268958_10100166546271786_5503106_47994114_8085937_n
Once it’s set up correctly, you can install the new timing chain set and/or chain tensioner.
The camshaft sprocket has a dowel that will only let it be installed one way, and the crankshaft sprocket has a notch that does the same. So if it fits and you can still pass the 20 pin check, then you’re all set!
Timing Chain Write-up 282790_10100166547733856_5503106_47994139_4606023_n
To reinstall the timing chain tensioner, move the tensioner block forward, lock it in place andslide it on and install the c-clip. Then unlock it to put tension on the chain and pick up the slack.
Next reinstall the oil slinger and the camshaft sprocket bolt, tightening to 80 ft lbs.
Timing Chain Write-up 284388_10100166548008306_5503106_47994143_5061547_n
Timing Chain Write-up 267938_10100166548093136_5503106_47994144_4052367_n
Time to prepare the cover for reinstallation!
Go ahead and clean up the old cover by scraping the old gasket off and getting rid of any grit and grime.
Timing Chain Write-up 281495_10100166548177966_5503106_47994145_7566874_n
Do this on the engine side as well, but make sure to cover the chain and sprockets to make sure you don’t get any grit into it.
Timing Chain Write-up 310607_10100166548472376_5503106_47994151_302819410_n
If you’ve got everything apart, you may as well replace the oil seal in the cover. Not required, but take a look and decide if you’d like to.
If you do, drive out the old seal. The manual recommends a screwdriver.
Timing Chain Write-up 284349_10100166548217886_5503106_47994146_4568203_n
This, however, was completely ineffective. I ended up just vice-gripping it and using a mallet to pop it out.
Timing Chain Write-up 267648_10100166548267786_5503106_47994148_6471444_n
Before putting in the new seal, make sure to coat it with a thin layer of oil.
Timing Chain Write-up 267621_10100166548372576_5503106_47994149_3134719_n
Then make sure it’s placed evenly and drive it in with a piece of wood.
Timing Chain Write-up 420541_10100166548432456_5503106_47994150_524723636_n
Now that it’s clean with the new seal in it, it’s time to apply the RTV. Put a thing bead on the sealing surface and around the bolt holes and smooth it out with your finger. Make sure to use a black, oil-safe RTV!
Timing Chain Write-up 268418_10100166548542236_5503106_47994152_6156100_n
Next throw on your gasket with another thing layer of RTV (I had to use my dental tools to keep the gasket in place while the RTV set.)
Timing Chain Write-up 268052_10100166548652016_5503106_47994153_4902600_n
While that’s setting, trim off the remaining tabs of the oil pan gasket sticking out and replace them with liberal amounts of RTV.
Timing Chain Write-up 270591_10100166548706906_5503106_47994154_4455193_n
Next pre-lubricate your new (rubber) oil pan gasket with a thin layer of oil and place it on the lip of the oil pan. (FYI, I had to cut off certain nubs that didn’t correspond with my oilpan. The screwholes were the primary aligning factor for me)
Timing Chain Write-up 283835_10100166548771776_5503106_47994155_6078977_n
Now reinstall the oil pan, putting the screws back in the appropriate holes using your handy-dandy diagram! Install all bolts hand-tight and then torque to 16ft lbs on the nuts and 7 on the oil pan screws.
Timing Chain Write-up 283125_10100166548836646_5503106_47994156_4985618_n
Then gently work the harmonic balancer back on (Made sure to line up the notch with the tab, or “wooddruff key”). Try and get it on without bashing on it, as that can damage the bearings. If needed, lightly tap in a circular pattern with a soft mallet to nudge it on, but only until it’s on enough to get the bolt and washer screwed in a few solid threads. At that point you can work the balancer on by screwing the bolt back in. Torque to 80 ft lbs.
Timing Chain Write-up 269587_10100166548881556_5503106_47994157_1629154_n
Timing Chain Write-up 420091_10100166548946426_5503106_47994158_1066920727_n
Timing Chain Write-up 282134_10100166549041236_5503106_47994159_2477161_n
Now reinstall the serpentine belt (don’t forget to tension), the fan and fan clutch, and radiator shroud. Reconnect your battery and you’re all set! (You may want to reset your PCM, but that’s up to you).
