Savvy/Currie 4" SA Kit vs Clayton 4" LA Kit
Page 1 of 1 • Share •
I know these are apples and oranges and the SA vs LA debate has been done. However, these are the two kits I have narrowed my search down to. Heres my take thus far:
Price- About equal when you factor in all of the extras needed for both kits
Quality: Again I will say a draw
Capability: This is where most of my questions are. Which one will fit the needs of the trails around us better.
So, what is everyones take on this matter. I really don't know which of the 2 would be better for my rig and the way I intend to use it. This is primarily a highway vehicle with some "weekend trips" from time to time.
KIT
Really, if one or other clayton la if more on road
Re: Savvy/Currie 4" SA Kit vs Clayton 4" LA Kit
I should mention I will be on 33x12.50
Currie 4" S.A. the long arm fad has faded, and if you intend on wheeling in this area and still maintaining a smooth ride I would go with the short arm kit. Better clearance, and nothing around here will require the articulation that long arms give you.
Thanks for the input. That was my thought as well. I started reading on JF and the consensus was 4" is max on SA.
Ryan M wrote:Currie 4" S.A. the long arm fad has faded, and if you intend on wheeling in this area and still maintaining a smooth ride I would go with the short arm kit. Better clearance, and nothing around here will require the articulation that long arms give you.
Ryan I wold have to disagree here. First the long arm "fad" has definantly not faded and with long arms you will have a waaaaaaaaaaaay smoother ride than with short arms. PLus there is some stuff around that long arms help ALOT. plus he plans on taking his rig to moab with me next easter.
For an all around rig that plays in the mud/rocks and takes long highway trips long arms are the way to go. My rig rides like a caddy now compared to the short arm lift I had before. I could tell you if a penny was heads or tails before not to mention while wheeling Disconnected being thrown around like a rag doll.
just my .02 if the cost is going to be the same why not go with a better lift that will make your rig more capable in the future? just sayin
donnyb373- Daily Driver
long arm
I agree , long arm. I have installed and test driven a few long arm kits and they ride so much better .
As for la or sa, as long as you are out there that's all that matters.
They both have their pros and cons.
Thanks for the input guys. I think I am going with the Savvy/Currie 3". Being that its all JJ it will ride well and have plenty of flex. I guess we will see how many times I get stuck at Moab.
I ran short arm kit for about 5 years, and when I upgraded to a long arm kit, the ride was 100x's better. I am waiting on Bilstein Shocks which will improve the ride significantly. Do what your budget allows and what you feel happy doing. I learned that a long time ago....
