Shock boots or no boots?
Shock boots or no boots? Empty Shock boots or no boots?
Post  Rob Cote on 5/24/2016, 12:11 pm
Do you prefer to run shocks with or without boots? Let's gather actual evidence here.
The white shock on the right here is about 1 year old, installed with a boot (boot removed for clarity). No maintenance (i.e.- I didn't drain water or otherwise touch the shocks during the time they were installed).
Shock boots or no boots? 7JCUx9P
Shaft is clean. No signs on leakage from the seal. Functionally, seems 100%.
Shock boots or no boots? Empty Re: Shock boots or no boots?
Post  Mark on 5/24/2016, 12:14 pm
It all comes down to preference,, but i will say that my kx250 came with boots on the fork tubes for a reason and the jeep and bike do kinda run in the same environment .
Post  Mark on 5/24/2016, 6:20 pm
Nice looking shock Rob, is that a built in bump stop i see there on the new shock ?
Post  RubiconBob on 5/24/2016, 6:51 pm
I run boots because the shocks came with them and saw no need to take them off.
RubiconBob
RubiconBob
Post  Tonellin on 5/26/2016, 9:07 am
No boot. I'd only run a boot in the desert or similar terrain
Boot in new england just traps water/salt/mud which leads to corrosion. Never seen a problem with shocks or steering stabalizers running bootless but have seem plenty of corrosion from guys that keep boots and run muddy trails
Post  Posimoto on 5/26/2016, 8:55 pm
^^^ This
Posimoto
Posimoto
Post  dongalonga on 6/4/2016, 9:21 pm
If Fox didn't provide boots, which they don't, there is no need to waste the time or effort.
978-979-9581 Cell
Post  Mark on 6/4/2016, 9:37 pm
Post  RubiconBob on 6/6/2016, 8:21 pm
Still being new to maintenance and all, how long would corrosion take to set in and diminish the shocks performance to the point of replacement, and how long would you expect to get out of shocks in either years or miles?
RubiconBob
RubiconBob
Post  AquilesT on 6/8/2016, 10:07 am
my rancho rs9000xl front i left the boots off and after 2 years i see no issue in the piston, the rears came with a open ended cover (not really a boot since its not stiff and not moldable like a normal boot) i haven't seen any leaks but the one side effect is that the cover has rubbed up on the shock body and now it has surface rust.
