TJ front sway bar
TJ front sway bar Empty TJ front sway bar
Post  jimaug87 on 4/15/2012, 7:51 pm
I bent the sway bar on my 05 Wrangler, and it appears to be affecting my steering. Anyone got a straight one I can buy if straightening mine doesn't work?
jimaug87
jimaug87
TJ front sway bar Empty Re: TJ front sway bar
Post  Ryan McKee on 4/15/2012, 8:50 pm
jimaug87 wrote:I bent the sway bar on my 05 Wrangler, and it appears to be affecting my steering. Anyone got a straight one I can buy if straightening mine doesn't work?
Do you mean the full bar that goes through the frame, or one of the end links?
If you mean the full U shaped bar, Clayton (SaxManClay) should have one. He just recently went to an Anti-Rock from the stock set up.
Post  jimaug87 on 4/22/2012, 2:46 pm
I need the full bar. My links stayed straight, but the hit pushed one side of the bar in towards the Jeep's mid line.
Thanks for the tip cheers
jimaug87
jimaug87
TJ front sway bar Empty sway bar
Post  Mark on 6/6/2012, 4:16 pm
did you get a sway bar?
Post  jimaug87 on 6/9/2012, 7:50 pm
Markmmaark wrote:did you get a sway bar?
Not yet. This one works. Plus, I have a few frozen bolts and I don't feel like cutting anything at the moment.
jimaug87
jimaug87
Post  saxmanclay on 12/5/2012, 9:28 am
I still have that bar if you want it.
saxmanclay
saxmanclay
