Ahhrrgg..... RUST
Ahhrrgg..... RUST
Post  JaFra on 6/15/2012, 11:33 am
I just noticed last week, that two rust spots about the size of a dime and about a half an inch apart, have popped up on my driver's side front fender. Anybody have suggestions on how to take care of this cancer before I have a giant-ass hole in my fender and have to replace it?
2007 JKU X in Steel Blue
33x16 BFG A/Ts on MKW M84's
Stubby antenna
that's about it, so far.
I still miss the old girl
Re: Ahhrrgg..... RUST
Post  Mark on 6/15/2012, 11:44 am
Yeah,, replace fender. Rust never sleeps.
Post  Jeepin Dave on 6/15/2012, 12:54 pm
Mine had holes straight through on both sides too. Common place.
Makes it a great time to upgrade to front flat tube fenders, since you cut that part of the fender off to mount the new one's. Breakage(or rust in my case) is just an excuse to upgrade.
Jeepin Dave
http://www.masskrawlers.com
Post  CrawlingForward on 6/15/2012, 1:13 pm
I've got the same hole in my fender.
Clean off any flaking paint, carefully shoot it with some Rustoleum Rust Reformer, then carefully shoot a color-matched rattle can at it.
Won't fix it, but it'll keep it from spreading.
Post  Andrew Miller on 6/15/2012, 2:11 pm
i was thinking of trying some bondo on both mine this summer. Ive got a few spots on my fenders, though i believe it is only on the tops
Post  janesy on 6/15/2012, 4:45 pm
Jeepin Dave wrote:Makes it a great time to upgrade to front flat tube fenders, since you cut that part of the fender off to mount the new one's. Breakage(or rust in my case) is just an excuse to upgrade.
That's what I would say/do as well, obviously not cheap, but a great time for an upgrade...
Post  Ryan McKee on 6/19/2012, 9:11 am
Or, if you're not in the mood to spend money on tube fenders (even the hack/install versions) you could cut out the small area, then either weld or rivet in a new sheet of aluminum and bondo/seal them together and add some touch-up paint. Basically along the lines of what people do with rusted out floorboards.
Post  Mark on 6/19/2012, 12:07 pm
There is a place i believe certifit.com.
Body parts for decent prices if i remember, a local jeep shop uses the fenders all the time in the body shop.
