I need seats
I need seats
My driver's is all beat and covered with duct tape. So I swapped it out for a Bestop fixed-back seat. The seat isn't horrible, but the bracket required to install it makes it so that I'm too tall now. I would like something, really anything. OEM or aftermarket so long as I'm not too tall. I'd like a recliner, if possible. I'll even go for junkyard seats if you guys know of a place that has any TJs. My back hates me every time I drive because I have to lean forward just to see the traffic lights. It's getting old really fast.
HELP!
HELP!
Re: I need seats
Swap the seats side to side for now, just remove the lever for incline on the side of the seat so it doesn't hit the console.
Leave the bottom brackets in place and just swap the seats them selves.
I don't know right now exactly what to tell you but I'll check around to see if i can come up with a seat for you.
Have to venture to Peabody to go to dentist.
Re: I need seats
I've got a good passenger side seat that came out of my YJ when I swapped in some cloth ones. It reclined no problem when it was taken out, and doesn't have the fat boy lean like a lot of the YJ ones tend to. If you can verify that it'll fit on your TJ brackets it's yours for $40.
Re: I need seats
I'm pretty sure that doesn't fit, unfortunately. Thanks for the offer, though.
Re: I need seats
WJ and ZJ seats are direct swaps, btw.
http://www.jeepforum.com/forum/f9/another-wj-99-04-grand-cherokee-seat-swap-into-tj-1112965/
Holland's Used Auto Parts in Billerica is a JY that usually has a decent selection.
YJs have a *ton* of various model direct swaps. But I don't know if there's a listing of TJ parts.
I know Clayton replaced the XJ seats a while ago with WJ? seats, so I wonder if his old XJ seats would fit....
Re: I need seats
I was just at Holland on Tuesday. Cherokees, Grand Cherokees and YJs for days. No TJs. Not one.
This was before I knew the WJ seats swap in (just found out today doing some research).
Re: I need seats
Rob Cote wrote:I was just at Holland on Tuesday. Cherokees, Grand Cherokees and YJs for days. No TJs. Not one.
Awww, man. Really? They *never* used to have YJ stuff. Always TJ.
Well hopefully you should be able to grab a ZJ or WJ for not too much cost then.
(Might even be able to get a heated seat out of the deal!)
Re: I need seats
Ryan M wrote:Will an XJ seat fit in? May be a stupid question. Thought I'd ask.
A quick google search suggests that the seats are identical, but the mounts are different.
So wouldn't you be able to just unbolt the XJ seat mount and bolt the TJ mount on?
Re: I need seats
OK, here it is guys
This is for ROB.
http://www.carworldused.com/searchinventoryonepart.html
Year
Part
Model Description Part
Grade Stock# US
Price Dealer Info
1997
Seat, Front
Jeep Wrangler DRIVER, GREY CLOTH WITH PURPLE,TEAL AND GREEN TRIANGLES A 1443J $75 Jeff Canter's Car World - ARAPro USA-NH(Candia) Request_Quote 1-800-500-8733 Request_Insurance_Quote
1997
Seat, Front
Jeep Wrangler PASSENGER, GREY CLOTH WITH PURPLE,TEAL AND GREEN TRIANGLES A 1443J $75 Jeff Canter's Car World - ARAPro USA-NH(Candia) Request_Quote 1-800-500-8733 Request_Insurance_Quote
This is for ROB.
Year
Part
Grade Stock# US
Price Dealer Info
1997
Seat, Front
1997
Seat, Front
Re: I need seats
I'm all for the idea of swapping in a WJ or XJ seat, my only concern is the height of the base. Does anyone know if you end up at about the same height as a TJ seat? I appreciate all the help and thanks for the link Mark. Hopefully I can scoop those party seats. If not, I'll probably be experimenting with junkyard cherokee seats.
Re: I need seats
Markmmaark wrote:Swap the seats side to side for now, just remove the lever for incline on the side of the seat so it doesn't hit the console.
This doesn't work. Ask me how I know.
Re: I need seats
Ok you have peaked my curiosity... HOW do you know?
I,m thinking that you tried it without success.
Re: I need seats
ding ding ding.
The passenger's seat got swapped onto the driver's slider. When I dropped it onto the riser, the seat hits the roll bar. It's because the mounting points on the bottom of the seat are not equally spaced about the longitudinal centerline of the seat, but rather the seat is inboard of the middle.
Re: I need seats
That's too bad, I would have tried also.
Oh well now we know, make a note of that.
Did you get the new seat ?
Re: I need seats
NOTED!
I'm heading up to Candia after work to grab the seats. Might scoot a wee bit early. IT'S SO NICE OUTSIDE!
» Inexpensive new seats, etc
» TJ Front Seats wanted
» Seats(s) wanted. Tan/Beige/Khaki TJ also possibly XJ, TJ, ...off brand?
