Code : P0456 Evaporative Emissions System - Small leak detected
Post  mr.steamy on 8/25/2012, 11:18 am
So earlier in the week my check engine light came on. I bought a code reader and P0456 Evaporative Emissions System - Small leak detected came up. So I did some research and saw that it could have been as little as tightening the gas cap. But then I got another check engine light on today with the same code. Has anyone else had this issue and is there more to it than what I'm thinking (gas cap)? Thanks!
mr.steamy
Re: Code : P0456 Evaporative Emissions System - Small leak detected
Post  JaFra on 8/25/2012, 11:29 am
It's the gas cap. The system takes about 130 miles to reset itself. It will also help for a few months at a time, if you coat the gas cap's rubber ring with vasaline. It restores the plasticity and creates a better seal.
2007 JKU X in Steel Blue
33x16 BFG A/Ts on MKW M84's
Stubby antenna
that's about it, so far.
I still miss the old girl
Post  mr.steamy on 8/25/2012, 11:43 am
JaFra wrote:It's the gas cap. The system takes about 130 miles to reset itself. It will also help for a few months at a time, if you coat the gas cap's rubber ring with vasaline. It restores the plasticity and creates a better seal.
I'll try it. Thank you!
mr.steamy
Post  dongalonga on 8/25/2012, 4:38 pm
Right on the money. It is definitely the gas cap.
