cherokee axxles on a tj
Post  bigmike on 6/12/2013, 4:25 pm
so i found a 98 grand cherokee for a grand im thinkin axle swap to a 97 tj. its d44 rear and d30 hp front will it bolt up
bigmike
Re: cherokee axxles on a tj
Post  Mark on 6/12/2013, 4:27 pm
What axles do you want to put in what?
Post  bigmike on 6/12/2013, 5:03 pm
from a cherokee to a tj
bigmike
Post  Mark on 6/12/2013, 5:34 pm
If it is a d 30 or d 44 from a grand Cherokee you will have to change the bracketry i believe.
Does the d 44 have an aluminum center section? if so forget it.
Never heard of a hp 30 inĀ  zj.
Just get a hp Dana 30 from a xj Cherokee, it will bolt right in with o mods.
A explorer 8.8 is a good upgrade from the dana 35 and cheap too, a bracket kit is about 200 dollars and you can find an 8.8 for about 200 also.
