Where do you get your driveshafts balanced?
I recently rebuilt the double cardan in my rear DS (its actually a cherokee front DS) replacing both U joints and rebuilding the centering ball. Either I lost or forgot to make a paint pen mark on the centering ball so I wasn't sure of orientation when I put it all back together. Because I lost the orientation I was thinking I should have it re-balanced.
Only place I've heard of around here is Montrose machine in Wakefield, they told me $65 for the single ds.
Anyone have a different place they go?
Re: Where do you get your driveshafts balanced?
WHY, is it vibrating now?
Hard to tell with all the other vibrations on my xj haha. Tire rumble alone is enough to mask most stuff.
I replaced the u joints because I had a bad one, two of the caps had no needles left in them, just powder. Didn't notice any vibration til it hit that point so its hard to say if I would be able to notice DS vibes. Its obviously way better than before but that doesn't tell me much.
No vibes = no worries.
If there was no external weight on it I wouldn't worry.
No external weight on the centering ball holder? There is not, only balancing weights are on the shaft itself.
I guess I won't bother unless I notice vibes on the highway, only taken it on the highway briefly since I did the repair.
Montrose Machine Shop in Wakefield MA used to beĀ $25....
