Exhaust(ing) Work
Exhaust(ing) Work
So for the past few weeks I've been working on replacing my entire exhaust from the header back. It's taken a LOT of work and has been extraordinarily annoying, as far as I'm concerned, but I am almost done, pending the arrival of the 2 new O2 sensors from RockAuto.com.
I first cut out the old muffler on the trails a few months ago during a club run, and then ran only a cat/front pipe for 3 months. Unfortunately the front pipe rusted through and there was a massive exhaust leak out the header (bye bye, MPG) so I finally replaced it. Problem was that the bolts were rusted and seized, so I had to cut off the output of the header flanges and fab up a new flange mount for the front pipe.
Then went in the Magnaflow front pipe & catalytic converter system, followed by modding a Banks Monster 2.5 muffler/tail pipe. That wasn't much fun either, as I had to weld together a bracket to get the muffler to couple to the catalytic converter output.
Old Cat/Front Pipe, and header flange that needed to be cut off
New Magnaflow kit
Then came routing the new Banks system
And welding a new coupler
Now I just need those NTK sensors and I'll have a real exhaust again!
New Magnaflow kit
looking good
Hey RYAN. It looks like you have things under control over there.
Almost done ,good job.
Re: Exhaust(ing) Work
Thanks Mark! Almost there... now I'm just waiting for the downstream sensor to arrive.
Upstream came today!
exhausting work
Hey RYAN, The exhaust sounds great , i'll bet you are relieved to have it finished.
Now it is time to start on another mod. Will it ever end.
Markmmaark wrote:Hey RYAN, The exhaust sounds great , i'll bet you are relieved to have it finished.
Already busy planning for the next one.......
Wheeling soon?
» Exhaust Time!
» Exhaust Question
» YJ exhaust/steering column/brake parts
» High rpm idle, no gauges, white colored exhaust
» Photos from work...
» Exhaust Question
