Third Time's the Charm LJ
Page 2 of 8 Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Third Time's the Charm LJ - Page 2 Empty Re: Third Time's the Charm LJ
Post  dongalonga on 4/8/2014, 1:40 pm
Thanks guys. The headlights will be very nice and not obnoxious once stage 2 gets completed.
I keep waffling on 35s. There are so many more things to consider to run them. I may just build everything other than the tires and lift in anticipation of the 35s.
Post  dongalonga on 4/14/2014, 6:19 pm
Today's Jeeping
Genright Rear Crossmember Bumper
First things first. This rig has had a rear end collision on the drivers side courtesy of the previous owner. What did that mean in terms of this install? It means it was a total pain in my ass....that's what it means! :brickwall
Now that we have a basis for the install, here is how it went down.
Rust sucks and it will not be tolerated:
Third Time's the Charm LJ - Page 2 Imagejpg1-15
Third Time's the Charm LJ - Page 2 Imagejpg1-16
The entire crossmember was cleaned up with a wire brush followed by cleaning with mineral spirits:
Third Time's the Charm LJ - Page 2 Imagejpg1-17
Third Time's the Charm LJ - Page 2 Imagejpg1-18
Then the entire thing was given a nice shellacking with Rustoleum:
Third Time's the Charm LJ - Page 2 Imagejpg1-19
Mmmm so clean:
Third Time's the Charm LJ - Page 2 Imagejpg1-20
Too bad it didn't stay that way. I allowed the surface to dry for several hours before attempting to fit the bumper. That's when things got interesting. The entire crossmember was out of square and the bumper didn't not want to go over the drivers side end at all.
After much massaging with a cornucopia of hammers, vice grips, pliers, and c clamps I got the damn thing on. I threw in a couple of bolt and nuts I had laying around to keep things in place and called it a night. Sorry there are no pics of this amazing fun process as it was dark and work was done by flashlight at this point.
I have to give a big thanks to my lovely little lady for her help. She was very patient through the whole fitting process. She was an extra pair of hands, a light holder, and even a tool wielding helper at points. I could not have finished this project without her help. She will be rewarded for her hard work don't you worry :kiss:
With all that being said, I went out today to get the necessary hardware. I drilled the four holes in the center section of the crossmember for 3/8" hardware (mostly because my crappy drill won't accept my 7/16" drill bit). The outer holes were predrilled for 7/16" hardware. All grade 8 hardware was used to secure the bumper. As you may have guessed not all of the holes lined up perfectly. No worries a quick hit with the Dremel and grinding stone make quick work of any offending holes.
I made sure to spray behind the bumper to recoat any areas rubbed off during the fitting process. Then I hit the bumper with a quick coat of black wrinkle finish paint. Unfortunately it got really windy after the first coat, so I will have to wait until another day to finish off the paint work.
Here is the end result:
Third Time's the Charm LJ - Page 2 Imagejpg1-21
I will eventually make a bike carrier that mounts to the brackets normally used for a tire carrier. I think that monstrous D Ring will do the job when I eventually get myself stuck. The only stinker is I could not use the frame tie ins due to the crossmember being so out of square. I may try to tackle that's somewhere down the road.
Post  dongalonga on 4/17/2014, 5:17 pm
Today's Jeeping
Removed the HIDs. I had Ddm Tuning send me a return label for the H4 conversion housings. I couldn't deal with the glare I was throwing at people. Phase 2 should be right around to the corner, as I can't deal with the stock lights for too long
Post  dongalonga on 4/18/2014, 11:05 pm
I have a confession to make. I'm a sucker for a great product at a great price...I ordered TruckLites today from NAPA for $320.
Best part is its in NH so no sales tax or shipping costs. I love me a bargain.
I pilfered the 55w ballasts from the Jeep's now defunct HID kit and put them in the Prius C. I wasn't happy with the 35w output and was going to upgrade them anyways. The only waste from the HID kit will be the bulbs, which I can always pass on to someone else.
Post  Andrew Miller on 4/19/2014, 10:18 am
I was considering trucklites a couple weeks ago, then I saw the price... My stock headlights work great anyways, maybe someday down the road. They are going to look sweet!
Post  Andrew Miller on 4/19/2014, 10:27 am
BTW, the Genright rear bumper looks great! Clean look
Post  dongalonga on 4/19/2014, 2:42 pm
Thanks Andrew. I need to throw another coat of paint on it. I'm pretty bummed the frame tie ins won't work. Maybe my body guy can get them in next week.
Post  dongalonga on 4/19/2014, 8:40 pm
Today's Jeeping
I put together a Useful Things Kit today. This is not to be confused with the mythical Girly Things Kit. However, it is no less awesome to have on hand. Jenny isn't high maintenance and has a purse full of the few things she could ever need. It is, however, a good idea to be prepared for some of life's curveballs.
Size constraints are ever present in the Jeep. I made sure to keep it compact:
Third Time's the Charm LJ - Page 2 Imagejpg1-22
What's inside:
Third Time's the Charm LJ - Page 2 Imagejpg1-23
A little of this and a little of that. There are a few categories.
-Hygiene-
Waterless tooth brush x2
Travel size toothpaste
Floss sticks
Chap stick x2
Hair ties
Nail clippers
Nail files x2
QTips
-First Aid-
Coban
Transpore
Micropore
Nitrile Gloves
Band Aids
Alcohol wipes
Gauze Pads
Scissors
Naproxen
I'm sure there are things in the future I may add or delete, but this is a solid start.
Post  dongalonga on 4/21/2014, 6:05 pm
Today's Jeeping
-CB Install-
I used the Rugged Ridge CB mount. Went it very easily. Nice snug fit for the CB so it doesn't bounce all around and rattle.
Third Time's the Charm LJ - Page 2 Imagejpg1-24
The CB mount also came with a mic mount that attaches slightly below and to the right of the steering column.
Third Time's the Charm LJ - Page 2 Imagejpg1-25
I used an add-a-lead that tapped into the radio fuse. I used a 5amp fuse and the provided 2amp inline fuse to protect everything. I used one of the the bolts from the now removed radio security bar for the ground. I ran all of the wiring under the upper dash panel so it is nice and clean looking. Then I ran the coax to the back following the wiring harness on the underside of the tub rail. I zip tied everything to keep it tight and clean looking. Installed the Teraflex CB mount, wiring and antenna.
Third Time's the Charm LJ - Page 2 Imagejpg1-26
Overall it was a very straightforward and easy install. I will tune the antenna before my trip next weekend.
Post  Andrew Miller on 4/22/2014, 12:03 am
Thats a great CB mount!
Post  dongalonga on 4/22/2014, 12:48 am
Yeah I really like the location. Does anyone have a SWR meter they can bring Sunday?
Post  dongalonga on 4/22/2014, 7:37 pm
Today's Jeeping
The Trucklites are in. Took all of 5 minutes to take out the old and put in the new. Waiting for it to get darker to aim them and get some output shots.
I also ordered one of these today:
http://www.moparamerica.com/oe-mopar/5166003ab?search_str=5166003ab
I am slowly going through the rig to find all of the little issues that need my attention.
Finally, I wanted to post some pics of the 550 cord grab handles and zipper pulls a buddy of mine made up for me.
550 Cord Porn:
Third Time's the Charm LJ - Page 2 Imagejpg2
Third Time's the Charm LJ - Page 2 Imagejpg1-29
Third Time's the Charm LJ - Page 2 Imagejpg1-28
Third Time's the Charm LJ - Page 2 Imagejpg1-27
Post  dongalonga on 4/22/2014, 9:31 pm
Trucklite Install and First Impressions
Install almost isn't even worth noting as it is that simple. If you have replaced a stock sealed beam, you have essentially done the most difficult part of this install. The reason I say this is because aiming them is far easier than a sealed beam headlight. Why you ask? Ultra crisp cutoff that's why silly:
Third Time's the Charm LJ - Page 2 PhotoApr2281545PM
I seriously think it took me 1 minute to aim both sides. I always cover one light and aim the other to eliminate bleed over from the other light.
The beam pattern on these things is friggin WIDE!
Third Time's the Charm LJ - Page 2 PhotoApr2281530PM
The high beam has a very nice fill and controlled cutoff:
Third Time's the Charm LJ - Page 2 PhotoApr2282216PM
And look at that beautifully wide light spread:
Third Time's the Charm LJ - Page 2 PhotoApr2282236PM
Low beams + LED Flood Lights:
Third Time's the Charm LJ - Page 2 PhotoApr2282410PM
Third Time's the Charm LJ - Page 2 PhotoApr2282426PM
Third Time's the Charm LJ - Page 2 PhotoApr2282454PM
LED Flood Lights alone:
Third Time's the Charm LJ - Page 2 PhotoApr2282513PM
Third Time's the Charm LJ - Page 2 PhotoApr2282527PM
Some road shots (a little blurry sorry):
Third Time's the Charm LJ - Page 2 PhotoApr2283149PM
Third Time's the Charm LJ - Page 2 PhotoApr2283215PM
Third Time's the Charm LJ - Page 2 PhotoApr2283219PM
And a shot of the output in a completely unlit area:
Third Time's the Charm LJ - Page 2 PhotoApr2283600PM
Now for my first impressions:
-They are adequately bright but nowhere near the output of a HID projector.
-They have a stepped pattern as can be seen in the road pics.
-They have the X artifact you have most likely read about (I don't believe this will be a showstopper though).
-They have a very wide pattern which allows you to see the shoulders of the road.
-The color is good. Not really sure how to describe it. They are not pure white but a mixture of colors (easy on the eyes).
For the money spent, the warranty, the ease of installation, and the performance I feel these are a good not great investment. For my budget and needs, they are all I can expect and then some. If you are looking for maximum output and pattern, you should look into JW Speakers (LED projector) or some form of HID Projector retrofit (many sources).
Post  Jake on 4/22/2014, 10:25 pm
Wow, looks seriously bright in those pictures!
Post  dongalonga on 4/22/2014, 11:17 pm
The camera really picks up the light well.  Honestly, there was too much ambient lighting for me to really have to rely on the headlights.  I cant wait to see them on a completely unlit back road!
Post  dongalonga on 4/24/2014, 6:05 pm
This is where the Jeep is at now. The only plans for the rest of this year are:
-Going to the body shop next week to repair damage/touch up paint
-Clean up and recoat any surface rust on the frame
-Possibly add a winch
-Hit some trails
Third Time's the Charm LJ - Page 2 Imagejpg1-30
Post  dongalonga on 4/28/2014, 12:22 pm
Today's Jeeping
The rig has been dropped off at the body shop. He going through the whole thing, pulling dents, and touching up all the bad spots. He is also going to straighten out the rear crossmember so I can install the frame tie ins for the bumper. Can't wait to see how it all turns out.
I also ordered a few things from Amazon. I signed up for an Amazon CC, which in turn got me a $50 gift card. Total for the order $0! Can't beat that.
The order consisted of a HD CB antenna spring. I accidentally ordered a medium duty, which flopped around like crazy. I also ordered these:
http://www.amazon.com/gp/product/B00JM22GHW/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
They look pretty trick and I have never seen anyone run them before.
Post  dongalonga on 5/1/2014, 6:44 pm
Today's Jeeping
I received my light mounts today. Not so sure about the FU for a company's initials:
Third Time's the Charm LJ - Page 2 3421FE71-8964-43C3-BA04-1FA47B097213
These things are slim and trim. Lightweight is always something I take into account.
Third Time's the Charm LJ - Page 2 E1636521-40AB-46F3-A0A0-1D8823E721DB
I thought this was a nice touch. A little anti seize should alleviate any rust issues or stuck bolt.
Third Time's the Charm LJ - Page 2 1CDAF0CA-939A-49C4-87E4-D305D88B445E
Another nice touch is the per installed neoprene backing.
Third Time's the Charm LJ - Page 2 3B0E3B09-89A4-4EC0-91B7-021DD14DC5AC
I will be picking up the LJ tomorrow and get these installed this weekend.
Post  dongalonga on 5/2/2014, 11:15 pm
Today's Jeeping
Replaced the whimsy medium duty (why do they even make these) spring with a proper man spring:
Third Time's the Charm LJ - Page 2 D7947BDE-E03F-4B31-8D2A-6B545AF96CF7
Picked up the Jeep from the body shop and it looks....well brand new!
Third Time's the Charm LJ - Page 2 5B1186D1-8E07-4C9B-B586-C4361DC49EAB
Third Time's the Charm LJ - Page 2 C19682B6-EDB3-43E2-9790-340FC2FFE0CD
Before and after:
Third Time's the Charm LJ - Page 2 Image-4
Third Time's the Charm LJ - Page 2 Image-7
Third Time's the Charm LJ - Page 2 Image-8
Third Time's the Charm LJ - Page 2 79564FA6-B8F1-42E4-900D-C17AC5091E2B
Third Time's the Charm LJ - Page 2 8D3D0C87-91CE-4433-B672-C7CEDB95C678
He also went through and touched up all the rust spots on the fenders, hinges, hood, and grill. He buffed out the wheels and soft top windows. And he also straightened, re-painted, and installed the rear bumper and frame tie ins:
Third Time's the Charm LJ - Page 2 B1E999BF-CBD5-4CBA-9DFB-47626A0631E7
Third Time's the Charm LJ - Page 2 F7E9CD64-2D11-4969-8DDF-0145BFA22E03
Third Time's the Charm LJ - Page 2 06DAB321-E8C9-4293-8E38-28AD7326621B
The overspray on the tail pipe is from me painting the frame rail. Overall, I am ecstatic and so is Jenny. She said the Jeep looks like it isn't more than a couple of years old now. Money well spent IMHO.
Post  Jake on 5/3/2014, 7:48 am
Wow that looks great, where did you go and do you mind saying what you paid? I've never had and body work done so I literally have no clue what things cost.
Post  dongalonga on 5/3/2014, 1:40 pm
I only use one shop. Noel's Autobody in Pelham NH. I can't say what I paid, because I get a better than average rate as I've known him since I was born. He doesn't charge as much as the average guy and does well above average work.
Post  dongalonga on 5/4/2014, 10:11 am
Today's Jeeping
Replaced the sunrider pin on the driver side. Now I can use it without fear of the top breaking in the wind.
New vs Old:
Third Time's the Charm LJ - Page 2 D4609026-3438-41B9-B3A8-D841C8DF58DE
Post  dongalonga on 5/24/2014, 7:43 pm
Well folks here is the news. Jenny gave me a line of credit to build the Jeep. I was stunned and scrambled to put a build list together with the allocated funds. Here is the shakedown of what was ordered today:
MetalCloak 3.5" Gamechanger ARB Edition
MetalCloak Stocker Rockers
JKS BL
Savvy MML (Beasley)
Novak Shifter
Rugged Ridge SYE
Rubicon Driveshaft (Beasley)
1.5" Wheel Spacers
Teraflex Spare Tire Spacer
ZJ Tie Rod Conversion
31 Tooth Speedo Gear
33x12.50R15 Goodyear Duratracs
Looks like July 4th at Rausch Creek is my deadline to get everything installed and ironed out. It is going to be a fun summer!
Post  dongalonga on 5/27/2014, 8:12 pm
Received a call from Matson himself today. The suspension and rockers are 4-6 weeks out. Looks like I won't have the rig build for the 4th. Not a big deal as Rausch Creek will be fun either way.
Post  THOOPY3 on 5/28/2014, 4:37 pm
Break the mold and wheel the snot out of a stock LJ with 33s. Up-travel be damned!
