TJ 1" comfort ride rear coil lift
Post  Mark on 3/20/2012, 2:57 pm
Daystar TJ 1" rear comfort ride lift spacers , new in box
Works with stock springs. NOT the small spacers used in budget boost kit.
" Comfort Ride Suspension kits are the perfect choice for a lift that will not only increase vehicle height, but enhance performance. Improve ground clearance, allow for larger tires, utilize most of the stock components and improve the all around on & off road capabilities at an affordable price. This lift kit contains a new style rear spacer with a progressive helix. This new design prevents the coil from collapsing over itself. This prevents premature failure or sagging. "
Also I have one new set of 2" budget boost spacers.
Last edited by Markmmaark on 3/20/2012, 10:21 pm; edited 3 times in total (Reason for editing : Add Pic)
