Tire-Carrier Build
Page 1 of 1 • Share •
Tire-Carrier Build
Here's a condensed version of my tire-carrier build this past fall.
I used 3/16" 2" x 2" steel tubing, a Comp 4x4 HD spindle, and a De Sta Co 2,000 lb latch on the back. I also got an LED brake light from SuperBrightLEDs.com for $9. Total cost on the build was around $175, and I made it myself! Totally worth it, in my opinion. Especially because all the cheap tire carriers have shitty hinge points, so I was able to make sure mine fit perfectly and was burned in well.
The whole project took about 2 weeks to complete, probably about 2.5 days in total. It was my 2nd welding project, and has held up beautifully so far!
Cutting the steel/assembly of the swing-arm:
Installing the spindle, attaching the swing-arm & painting:
Installing on the TJ:
Re: Tire-Carrier Build
Nice Job!! that thing looks beautiful! I can't wait to finish my rebuild/swap so I can purge the rust and start building stuff like that
Where'd you get the steel? I see the helmet & gloves, (Nice hot tub!) but did you use Stick or Mig? also, where'd you get the bumper? or did you fab that too?
:Cheer's: to a siick tire carrier!
Haskie- Daily Driver
Haskie wrote:Nice Job!! that thing looks beautiful! I can't wait to finish my rebuild/swap so I can purge the rust and start building stuff like that
Thanks for the compliments!
I bought the steel in Wilmington from Markham Metals off 125, BUT I have 12 more feet of it if you'd like to buy it off me to build your own! (It's been kept indoors, 12' solid piece)
It's MIG built, with a Hobart 140. Bumper started life as a SRC Comp bumper that I hacked up.
If you're interested in buying the 2x2 steel, let me know! $75 for it, as I've got no other projects to use it on. 3/16" wall.
I can also point you in the right direction for the spindle and everything as well.
Where did you get the spindle and latch for the carrier? I'm designing a tire carrier myself to be built this summer
and would appreciate the imput
CGT2358- Daily Driver
Spindle is from Comp 4x4. If you want to read up on my build, there's a full build thread on JeepForum. Lots of good comments on there from other guys.
Be sure to read the offer above on buying the steel I have left over! It's open for anyone to buy, and is more than enough to build the swing out portion.
Swing Out Build - http://www.jeepforum.com/forum/f22/my-girl-boston-jeep-build-683603/index43.html#post12237428
Spindle Write Up - http://www.jeepforum.com/forum/f22/my-girl-boston-jeep-build-683603/index44.html#post12257701
Bumper Build - http://www.jeepforum.com/forum/f22/my-girl-boston-jeep-build-683603/index44.html#post12266146
Similar topics» Grey Ghost Gear Plate Carrier
» TRACTION OPTIONAL/Slammedenuff MATHIS TIRE PARKING LOT MEET!
» If you build it, will they come?
» No one can build
» [A-1556] SLK Build 0.8.4
» No one can build
