need help
need help
Post  marcus1993 on 5/11/2015, 6:48 pm
I am trying to fined a good performed chips to put in my jeep as I am going need one when I put a lighted and bigger tire ok my 2009 wrangler sarah
marcus1993
marcus1993
Re: need help
Post  Rob Cote on 5/12/2015, 12:48 pm
Re: need help
Post  AquilesT on 5/13/2015, 10:19 am
marcus1993 wrote:I am trying to fined a good performed chips to put in my jeep as I am going need one when I put a lighted and bigger tire ok my 2009 wrangler sarah
I assume you mean that you need a tuner because you will be upgrading you tires. I use the Flashcal since it also reads any DTC codes from the ecu but many like the AEV Procal
Re: need help
Post  marcus1993 on 5/13/2015, 10:24 am
Ya were can I get one of those
marcus1993
marcus1993
Re: need help
Post  AquilesT on 5/13/2015, 12:00 pm
marcus1993 wrote:Ya were can I get one of those
amazon or any other jeep/4x4 vendor..maybe even craislist
note: if you do get one from craigslist make sure its been reset/unpaired from the previous vehicle it was used on.
Re: need help
Post  marcus1993 on 5/13/2015, 12:19 pm
Ok will do thank for your help also what size tire to you recomed for a jeep with a 3.5 light
marcus1993
marcus1993
Re: need help
Post  AquilesT on 5/13/2015, 2:31 pm
marcus1993 wrote:Ok will do thank for your help also what size tire to you recomed for a jeep with a 3.5 light
35" seem to the most popular. you can certainly go bigger but you should look at your options based gearing (mpg's) and axle protection (gusset/truss) as bigger tires will require more work to have the same daily 'driveability/functionality'
Re: need help
