ebay / aluminum radiators
Anybody replaced their radiator with a 2 or 3 row all aluminum one like the units on ebay ?
I'm going to ned a radiator soon and i've seen stock replacement units on ebay for as little as 55 dollars and all aluminum units for 125 and up.
I found some nice looking all aluminum units for 160.
This one looks like the one i'll get.
http://www.ebay.com/itm/MOLDED-TANK-KKS-3-ROWS-ALUMINUM-RADIATOR-FOR-JEEP-WRANGLER-1987-2006-/222074702295?fits=Make%3AJeep&hash=item33b4af09d7:g:sPsAAOSw14xWKj0h&vxp=mtr
The winch, license plate, a/c condenser are all hindering air flow and the fact that the radiator is clogging up is causing it to run a bit too hot on the highway in summer.
Re: ebay / aluminum radiators
Was keeping an eye on this just because I plan to replace my radiator as well. Pinhole leak in the bottom. Was looking at at least a 2 row since Winch is blocking front cooling now (although my engine has never run hot before).
Only reason I havent done it yet to give you feedback is I blew a piston last week of February and its pretty bad so Im actually doing an engine fix, so ill wait til its in before even touching the radiator.
The 3 rows is probably best bet for you. I dont have a/c so ill probably just grab a 2 row unless i find a good deal.
Dave-NvincibleT- Mall Crawler
Oh man, good luck with the engine.
Yeah 3 row it most likely what i'll get.
Just had winning bid on radiator,$165.00, 3 row all aluminum 2.2 inch wide core.
I'll keep you posted as to how it fits and quality of product.
http://www.ebay.com/itm/3-ROWS-KKS-RADIATOR-1987-2006-JEEP-WRANGLER-YJ-TJ-LJ-2-4L-4-2L-L4-6L-KKS2101-/172167526030?autorefresh=true
I'm considering complementing radiator with their electric fan/shroud.
http://www.ebay.com/itm/KKS-ALUMINUM-RADIATOR-FAN-SHROUD-W-16-1987-2006-JEEP-WRANGLER-YJ-TJ-LJ-2101FS-/172146537807?hash=item2814bbb54f:g:83QAAOSwnipWVnog&vxp=mtr
