D30 Spartan Install
+3
7 posters
D30 Spartan Install Empty D30 Spartan Install
Post  dongalonga 4/16/2012, 10:11 pm
Spartan Locker D30
2005 TJ
Tools Needed:
Jack
Jack Stands
Tire Blocks
Means to remove wheels
Impact wrench (mine is an electric)
Torque wrench
Plier assortment
Bungee cords
3/8" ratchet
1/2" ratchet
3/8" breaker bar
1/2" breaker bar
13mm Combo Wrench
13mm 6 and 12 point sockets
36mm socket
5/8" socket
11/16" Combo Wrench
11/16" socket
Prybar assortment
Large pin punch set
3/16" drill bit
Hammer assortment
Bench Vise
Blue or Red Locktite
Plastic wrap and Elastics
Lubelocker or RTV
Gear Oil
Masking tape
Sharpie
Carboard/Big piece of heavy duty paper
Ok so on to the installation process. There were a few snags along the way that I will go into more detail on. Hopefully the snags I ran into can be avoided by reading this write up.
Step one: Order/receive parts
D30 Spartan Install 578548_10150682546327005_573207004_9609021_2124209339_n
D30 Spartan Install 398954_10150682546452005_573207004_9609022_488762993_n
Now onto the actual installation. First block rear wheels, loosen lug nuts, jack up, place on jack stands, and remove wheels.
D30 Spartan Install 524589_10150682546577005_573207004_9609024_1755717277_n
D30 Spartan Install 553320_10150682546667005_573207004_9609025_1135227132_n
D30 Spartan Install 545877_10150682546847005_573207004_9609026_1731250549_n
Next apply PB Blaster liberally (this is the only acceptable instance of being liberal) on all of the 13mm hub bolts.
D30 Spartan Install 550207_10150682546937005_573207004_9609027_1277661589_n
While waiting for the PB Blaster to do its thing, remove the drivers side tie rod and bungee cord out of the way. You will save yourself much cursing later on by doing this, so just do it.
D30 Spartan Install 535495_10150682547042005_573207004_9609028_657096949_n
Now go put another shot of PB Blaster on everything again then take some pics for your build thread.
Remove brakes and bungee cord calipers out of the way.
Make sure your steering wheel is unlocked to provide better access to the hub bolts. Get a BIG breaker bar and a 13mm 12 point socket and with even pressure break them loose. Then pop off the cotter pins and axle nut covers. Using the impact gun remove the 36mm axle nuts. Pull axles shafts and set aside.
D30 Spartan Install 578013_10150682547182005_573207004_9609029_1118832110_n
Next prepare that piece of carboard or heavy paper by marking up/down/left/right orientation. You will be taping your bearing caps and bolts to this. They HAVE to go back in exactly the way they came out. Remove diff cover and let drain completely. Take a reference pic just in case. Remove bearing caps and tape each piece down before removing the next.
D30 Spartan Install 581268_10150682547487005_573207004_9609032_594105937_n
Next was the first snag I ran into. My carrier was in very tight. I tried a few methods and couldn't get it to budge. I took a break to gather myself and look up alternate means. I will take this time to advise you SLEEP before you work on your Jeep. I worked the night prior and should have known brain function would severely decrease at this point. Look at it just laughing at me!
D30 Spartan Install 149438_10150682547727005_573207004_9609036_794127111_n
I finally stopped being a sissy and put an 11/16" box end wrench on a ring gear bolt and rotated it up to the top off the diff housing. I then used a pry bar to rotate the front driveshaft until it spit the carrier out. This was unbelievably easy. I don't recommend any other method it was that easy. Oh and don't be a tired little sissy like me!!
Alright now we're in business! Make sure when pulling the carrier not to let it spit the bearing races on the ground. These cannot be damaged in any way. Also make sure not to get any debris into the bearing. This would be a good time to place some plastic wrap over them and place an elastic at the bottom to hold the wrap in place.
Bring the carrier to your work bench. You cleaned it before you started right!? If not now would be a good time. Get out your punch set, impact gun, and socket for ring gear bolts.
Degrease the ring gear and carrier. Make a couple of reference marks between the ring gear and carrier. I made a wide one at the 12 o clock and a narrow one at the 6 o clock just in case they rubbed off. Remove ring gear bolts with the impact gun and set aside. Be careful with the last few bolts. Don't completely back them out. This will stop the ring gear from falling and possible being damaged.
D30 Spartan Install 553308_10150682548462005_797896712_n
D30 Spartan Install 530180_10150682548547005_573207004_9609048_925466761_n
Drift roll pin from ring gear bolt side using a long 3/16" punch. My punch was just a bit short. After a little research I found that a 3/16" drill bit would nicely knock the roll pin out the last few taps. A word of caution now is a time to be a sissy. If you use a drill bit be very gentle. Drill bits by nature are easily shattered so just lightly tap. Next drif out the cross pin using the 1/4" punch. Now just remove the side/spider gears and make sure the thrust washer are attached to them. You MUST make sure the thrust washers are out with the Spartan.
D30 Spartan Install 527337_10150682547937005_573207004_9609038_1938332717_n
D30 Spartan Install 535221_10150682548052005_573207004_9609040_1352905856_n
D30 Spartan Install 546516_10150682548147005_573207004_9609041_434559904_n
Next follow the instructions that came with your Spartan locker to get everything in the carrier. This was literally the only time the instruction booklet was useful. I had no issues here and don't expect you will either.
D30 Spartan Install 399005_10150682548222005_573207004_9609043_1069765696_n
Next put some blue locktite on the ring gear bolts. You already degreased them right!? Place the ring gear back on the carrier making sure to line up your reference marks. Put a few bolts on hand tight to hold the ring gear in place. Then put the rest in hand tight. Put the whole assembly in your vise and get ready for some fun.
D30 Spartan Install 562468_10150682548722005_573207004_9609049_61958496_n
D30 Spartan Install 575596_10150682549017005_573207004_9609050_1558786712_n
I bough the cheapest vise I could find, which never works out well. I first torqued all the ring gear bolts down to 55ft/lbs in a cross hatch pattern. The vise worked great for this. Then I went up to 80ft/lbs to be right in the middle of the 70-90 factory recommendation. This is where the fun began. This particular vise has a swivel feature and it wanted to swivel at 80ft/lbs. The solution? Bear hug the carrier and vise while torquing it down of course! This was not a loving hug mind you!
Ok so thats done and the carrier is ready to go back in.
When putting the carrier back in make sure it seats evenly. I used a sturdy rubber mallet to accomplish this. Then place the bearing caps back on in the correct orientation and torque down to 60ft/lbs. Pop the diff cover back on and fill with high quality lube. Or in my case the cheapest shit you can find!
D30 Spartan Install 534081_10150682549167005_573207004_9609051_293696148_n
D30 Spartan Install 553135_10150682549422005_573207004_9609052_1840267816_n
D30 Spartan Install 553064_10150682549622005_573207004_9609053_452809005_n
D30 Spartan Install 72970_10150682549727005_573207004_9609055_1119562691_n
Next feed the shafts back in carefully, install unit bearings, torque 13mm 12 point bolts to 75ft/lbs, install axle nut to 175ft/lbs, put on axle nut cover and cotter pin, bolt on brakes. Then reinstall the tie rod and torque to 55ft/lbs and reinstall cotter pin. Bolt wheels back on, remove jack stands, and torque lug nuts.
Next on the agenda was a victory shower. Then some time at the park with the dogs who were patient enough through this whole process.
D30 Spartan Install 528979_10150682549847005_573207004_9609056_507350373_n
Finally a celebratory meal inspired by another Jeeper!
D30 Spartan Install 577912_10150682549917005_573207004_9609057_935607620_n
Well that's it. I hope you enjoyed my occasional attempt at humor and technical savvy. Good luck with your future installs.
D30 Spartan Install Empty Re: D30 Spartan Install
Post  CrawlingForward 4/17/2012, 10:11 am
Awesome write-up, thank you! Super amounts of helpful details and detailed pictures!
(I especially like the Greta reference, ha ha)
Post  dongalonga 4/17/2012, 1:19 pm
The Greta reference was mandatory. That thread inspired my lazy self to do this write up.
I made sure to not the snags I ran into, as many write ups didn't seem to. If I can save someone a few mins of aggravation, I will be happy.
Post  Ryan McKee 4/20/2012, 8:23 am
D30 Spartan Install Anna-LowerShockMount2_640x480
Anabelle would be proud. cheers cheers cheers cheers
Good write up Shaun!
Post  JaFra 4/20/2012, 9:32 am
What a Face Anabelle!
Post  2003x 4/20/2012, 6:02 pm
Nice write up, you make it look so simple.
Whos Anabelle?
2003x
2003x
http://www.jeepforum.com/forum/f22/2003x-tj-build-944608/
Post  Ryan McKee 4/20/2012, 7:54 pm
Post  dongalonga 4/20/2012, 10:44 pm
Its only the greatest thread in JF history is all! Thanks guys. I will try to do write ups for the Savvy Under Armor and DPG Super Ultimate install as well.
I'm hoping I can get a few of you in on these as the extra hands would be greatly appreciated. I never relaized how much more work was involved when doing a write up.
Post  saxmanclay 4/23/2012, 9:40 pm
Next time you need help with something let me know. I'm just over the town line from and would be more than happy to assist.
saxmanclay
saxmanclay
Post  dongalonga 4/24/2012, 6:44 am
Sounds good and be ready. I have A LOT of parts incoming!
Post  donnyb373 5/6/2012, 3:44 am
We still good for a wrench day Tuesday?
donnyb373
donnyb373
Post  dongalonga 5/6/2012, 5:15 am
No. Jenny is coming back from NY Monday night, so we will be busy. Come down on Monday or this afternoon. I will shoot you a text.
