tj/xj dana 30 lp 3;55 ratio, dana 44 xj rear housing tj REAR BRACKET KIT and more
Dana 30 from my 97 TJ, 3;55 gear ratio all brackets are fine.
No knuckles or axles. MAKE OFFER.
tj REAR END BRACKET KIT NEW IN BOX COMPLETE 175 OR BO.
, MAKE OFFER.
TJ Warn winch plate, used b/o
, MAKE OFFER.
Re: tj/xj dana 30 lp 3;55 ratio, dana 44 xj rear housing tj REAR BRACKET KIT and more
Doing some early spring cleaning Mark??
What rear bumper is it? Also, what are you looking to get for the half doors?
Hey Mark, does the XJ 44 have the YJ spring perches still welded to it? And any idea what previous carrier was installed in it? I'm hoping to run 4.88s in my YJ eventually, but I'm not sure if that's possible with this axle. I'm very interested in it provided I can put the 4.88s in it. If you want shoot me a PM on the details.
Ignore my previous question about the 4.88s...I wasn't thinking straight. If it's totally empty then I could put whatever carrier I need in it for the numerically higher gears. Definitely still need to know about the perches and also the shock mounts.
I assume you don't have knuckles for a D30, but if you did.. I want some.
PM sent for bumper
nmill5321- Daily Driver
» low pinion TJ/xj dana 30 on CL Maine 373 ratio
» auto trans 97 tj needs rebuild // tj dana 35 housing, carrier n/g
» TJ rear seat
» Hi I'm Rob
» tj rear seat
» TJ rear seat
» Hi I'm Rob
» tj rear seat
