Lots of work to do. Who wants to help?
Hey guys! The week during and after X-mas I have a lot of time off, specifically from Dec. 26-Jan 2. During that time I will be doing the following:
-Install new brakes (front and rear)
-Rear drum to disc conversion
-New brake lights
-New rear bumper with reverse lights
If any of you want to come over to my parents house and help out, it would be greatly appreciated. Even if it's just for half an hour to stop by and say hello or really get into the work, it would be awesome to see any of you. Let me know if you'll be stopping by in the comments.
-New brake lights
saxmanclay- Mall Crawler
Re: Lots of work to do. Who wants to help?
Hey Clayton, what do you have for a rear end , 35/44?
Did you source parts or are you using a kit?
I did mine, I used parts from a 1998 v8 grand cherokee and e brake cables from a rubicon.
You have to swap wheel studs ( THE WHEELS WILL BOLT ON BUT ONLY BY A COUPLE OF THREADS) do not skip this step ! Unless you have after market axles with extra long studs.
You have to use studs for the grand cherokee 1995 to 1998 v8 with rear disc brakes, I forget year exactly,,, because the rotor you will be installing is alot thicker than the brake drum that you are replacing!!!
You should do while you have axles out and replace axle seals while you are there even if they are not leaking.
Good luck,, Mark..
Good luck,, Mark..
Markmmaark wrote:Hey Clayton, what do you have for a rear end , 35/44?
Good luck,, Mark..
I got the parts from a 96 Grand Cherokee. And good point about the wheel studs. My wife has the rear disc swap on her 8.25, and I noticed that she needs some slightly longer wheel studs too. I'll definitely pick some up before I start.
I got calipers from salvage yard when i got brackets and backing plates etc.
I used the calipers for a core at auto zone, now they have warranty and are rebuilt too.
You should get and make new 3/16 brake lines, just measure after e thing else is done.
I drilled holes in coil spring buckets to bolt on grand cherokee rubber hoses and then made new 3/16 lines.
I may have the studs you need. I will take a look.
You're in luck. I have all 10 that I didn't end up using. PN 4762841
dongalonga wrote:I may have the studs you need. I will take a look.
Nice! What are the chances of me getting them off of you?
Pretty low. Shaun's a tricky guy... always says he's gonna make it somewhere, never shows up.... time after time......
Hey now. I am available Sunday after 2pm. Let me know where you want to meet up.
BTW Ryan when are you going to tune my CB
BREAKER !! BREAKER !! Good buddy got your ears on? LOL
Clayton, I could press them in for you, I have a shop press but i'm here in Haverhill.
Kind or far to go just for that, but if you need to let me know.
Markmmaark wrote:Clayton, I could press them in for you, I have a shop press but i'm here in Haverhill.
I actually live in Lawrence now, but I'll be doing the work at my parents house. I could easily stop by one day and have you press them in. That would be fantastic.
No problem i'm here most of the time. I will pm you my cell #
You do mean stop by with axles in hand?
See? This is why I miss you guys.
This thread = Lots of awesome people that I miss all helping out!
I'll only be back in Boston from tonight through Christmas Day, but I hope everything comes together!
Still need those studs? Never heard back from you.
dongalonga wrote:Still need those studs? Never heard back from you.
Yes I do. Sorry for the late response. Could I pick them up tomorrow?
That shouldn't be a problem. Text me when you're ready 978-979-9581
Wednesday is good to come over.
» Exhaust(ing) Work
» Photos from work...
» Hey from Middleton!
» ( SOLD) 91 yj needs work or for parts
» Anybody else work from home? Weekday runs...
